Sponsored by: CARiD
My 04 Lariat just finished 6'' Lift
Old Mar 4, 2008 | 11:47 PM
st1nn3tt's Avatar
Thanks for all the feedback
Old Mar 5, 2008 | 01:06 PM
champaroo's Avatar
Originally Posted by st1nn3tt
That's strange that your tie rod ends rub. I've got half an inch or more from any rub at full turn. My back is also level with front, but I was careful to make sure it would turn out that way as I installed the lift. This was my first lift install.
sorry for stealing a post but i cant send private messages yet
just curious i am doing my first install tomorrow did you run into any bumps? i have read over and over my instructions for my 07 and i beleive im ready but is there anything as a noobie i should be aware of anyone? i found i link this guy put pic by pic the install with description but i just want to be sure. does anyone know on the from lower control arm cam bolt i heard something might have to be done there to get the alignment?
Old Mar 5, 2008 | 05:17 PM
st1nn3tt's Avatar
You'll be fine if you've read the instructions and have the pic by pic install. Just be sure you spray all your bolts with blaster a day or two before and drive around b/c some of the bolts are hard to get off.
Old Mar 6, 2008 | 02:08 PM
Shepard69's Avatar
Can't remember if the instructions mention it, but try and use a floor jack to get new the parts "under load" when when bolting thing together. Basically once all of the drop brackets and A arms are back in, jack it up a little before your torque down all of the nuts.
