Camburg or Total Chaos
Originally Posted by MercedesTech
Camburg = MAX of 5" back spacing on wheels
Total Chaos = MAX 4.5" of backspacing.
Just so ya know. I will run Camburg. Both are very comparible, I think i would put Camburg a half step over TC. Just my opinion.
The backspacing is only and issue If your running the factory spindles. If you lifted 6" or higher and using the spindles from the lift kit then there backspacing requirements are not a factor because the lifted spindles raise the upper control arm knuckle higher ( i'm running 37's and the top of my knuckle is 2" higher than my tire)
And i also agree with you that they both are pretty much the same.
