Sponsored by: CARiD
Rear Shock Replacement
Old Feb 20, 2008 | 09:45 AM
dfishrmn88's Avatar
I have an '05 Scab XLT 4x4 5.4L with 17,800 mi. Still have the factory shocks on but I think the rears are starting to go. How can I tell for sure if they are wearing out? There is no leakage but they can be depressed easily between my hands. Fronts are still good, checked them when I installed the AS 2" level kit. Second question, I know it would be best to replace all 4 at once but is there a draw back to replacing only the rears? I do load the truck occasionally, normally 500 - 700 lbs but have been up to 1500 lbs.
Thanks for your help.
Old Feb 20, 2008 | 10:24 AM
BlueF150_guy's Avatar
After you depress the shock, does it rebound back out? sounds like the shocks are just about worn out to me. The stock rears are pretty lame IMO, I replaced the rears at about the same mileage that you are at, I'm now at 31,000 miles. I threw on some Pro Comp ES9000 on the rear and still have the stock fronts with the AS2 kit as well and all has been fine. I haul dirt bikes around alot and the ride has been great with bikes or with out. No problems here.
Old Feb 20, 2008 | 09:41 PM
funtuff's Avatar
Guys,
I have a 2.5" leveling kit on the front and a 1.5" AAL on the rear. My ride is very stiff. When I ride over a speed bump it very rough. could my front shocks be over extended? I went by a 4x4 shop and the guy told me that I didn't have shocks on the front... he called them struts and said that i only needed to replace the rear shocks. I'm no suspension guy but I don't think I have struts. I thought they were coil-over shocks. He said it would cost about $180 to do the rear and over $400 for the fronts. I was thinking about bilsten 5150s series. Can someone please assist? Oh, btw I have a 06 FX4Screw.
