Sponsored by: CARiD
shock question
Old Feb 6, 2008 | 11:02 PM
K.R. F-150's Avatar
shock question
i have a pro comp 6'' lift not installed yet. i know the rear is going to be 1.5'' lower than the front. if i put a 4'' block in the rear instead of the 2.5'' block they give will the es9000 shocks be ok or will i have to get different shocks? also will the u-bult be long enough? thanks for any help
Old Mar 7, 2008 | 12:06 PM
JonnyT's Avatar
HAHA I was wondering the SAME question. I just got the pro comp 6" and am waiting on backordered wheels Can anyone help us?
Old Mar 7, 2008 | 04:25 PM
st1nn3tt's Avatar
Ok I just put my 6'' Pro Comp lift on a couple weeks ago. I used the 2.5'' block the kit came with and my rear is less than a quarter inch lower than the front, so it's basically level. As for the shock, I do think you will need a bigger one. As for the U-bolt, I KNOW you need a bigger one. There is only an inch left (if that) on mine and i'm using the 2.5'' block.
Old Mar 10, 2008 | 12:30 AM
JonnyT's Avatar
Good to know, thanks St1nn3tt!
