will 33's clear
Wendall- I have a 2003 F150 4X4 with stock 17's and i was thinking about going to 305/65/17. Would they fit with out cranking the torsion bars? Also would it look better if i did and does cranking the torsion bars hurt anything?
Yes, they will fit. They will look better if you crank the torsion bars enough to level the truck. As long as you don't crank up the torsion bars to the point of creating crazy ball joint and CV joint angles you will be fine.
