maybe getting 8in. out of a 6in.
Ok i thought about trying to build my truck to go fast but ive dumped that idea. This is what i want to do, and i was needing some info.
I want to buy a 6in. pro comp, I know its not a rize or what not, but my truck will never see off road. I was wondering if this lift comes with a block to lift the rear, and if it does, can i put a 2in. AAL on the back, and a 2in. leveling kit up front to achieve 8in. of lift.
Another question can i run 37/13.50r20s this 4.5 to 5 in. backspacing, and if not could i run 37/12.50r20s with no rubbing.
just one more question does the pro comp lift come with steering stablilizers?
if you want to run a 8" leveling kit with a lift, youll want the fabtech kit. its not wise to stack a 2" leveling kit on top of the 6" spacer that is used in the pro-crap kit.
i dont think any of the basic lifts come with steering stabilizers but the fabtech kit is only about $140
Do you have a 1999? .. or do you have a 2004+ F150? I'm kind of confused because you said you know it's not a Rize, they don't make lift kits for any body style but the 2004 F150. But if you do the 8" of lift, you should be able to run 37x13.50 with some minor trimming.
