Sponsored by: CARiD
08 FX4 rear 1" low... Block Question???
Old Jan 20, 2008 | 03:20 PM
CRJ Pilot's Avatar
08 FX4 Rear 1" Low... Block Question???
I did a Skyjacker 6 inch lift and added a 2 inch spacer to the front. As a result, my rear sits one inch low. I installed the aal that came with the kit. I do not want to install another aal. Its stiff enough as is.
My question is about blocks. The stock 2 inch blocks have bump stops. Are there any 3 inch blocks I can purchase that have bump stops? If not, could I stack 1 inch blocks (not my ideal situation)? Do I even need the bump stops? I cant imagine ever making my truck bottom out, but you never know? Also, where should I buy my new blocks from? Thanks guys!
Old Jan 20, 2008 | 04:52 PM
07screw's Avatar
as makes a 3" block with out the bump stops that's what i used to level mine up
also you can get a bigger aal to use in place of the one your using
Old Jan 21, 2008 | 10:29 AM
DIHLON's Avatar
Can you get a 1" block? If so, where can you get them?
Old Jan 21, 2008 | 12:06 PM
MercedesTech's Avatar
best bet is contacting Fabtech or a known Febtech distributor. They make both a 3" rear lift block and a 5" rear lift block. These REPLACE your factory lift blocks. It is VERY unsafe to stack any sized blocks. Also, you may not think your going to use the bump-stop, but its better to have it and not need it, then need it and not have it. 99% of the time you wont use it, but that one time you do, you'll be glad you have it. Fabtech makes some quality lift blocks. Check em out.
Old Jan 21, 2008 | 02:23 PM
marcus1033's Avatar
Autospring makes 1.5 inch blocks.
Old Jan 21, 2008 | 02:27 PM
CRJ Pilot's Avatar
Thanks Mercedes. So the Fabtech blocks do have bump stops?
Old Jan 21, 2008 | 02:31 PM
yes, definately do CRJ pilot. They are heavy duty steel, painted black. I can nab a pic of mine later tonight if you want (at work and didn't drive the truck today)
Old Jan 21, 2008 | 02:36 PM
CRJ Pilot's Avatar
I dont need a pic. I'll take your word for it! I've already made up my mind and will do the Fabtech. Thanks!
Old Jan 21, 2008 | 10:14 PM
07screw's Avatar
there is a set of 3" fabtech blocks in the classifieds right now hope this helps
Old Jan 23, 2008 | 12:31 PM
boyd220's Avatar
You can use 2 wd shackles and will give about 1 1/2 inch and not affect ride. Canuck motorspor has them on ebay for about 70 dollars
