Sponsored by: CARiD
Spacer ???
Old Jan 17, 2008 | 02:40 PM
NWAF-150's Avatar
Spacer ???
I am debating putting my spacer back on to clear up some tire rubbing issues with my 6 " lift kit I was told it was a 2" but how do tell the difference, does anybody know the thicknesses of the different sizes if they do and mine is off I can always mill it down but I need to know the exact thickness. I would prefer to just go 1.5" in the front and add a 2" leaf in the rear to give it just a slight angle forward but if nobdy knows the measurement of a 1.5" spacer a 2" would do.
Old Jan 17, 2008 | 02:42 PM
gators241987's Avatar
if i were you, i would just trim it. putting a spacer on top of a lift is pretty harsh on the cv angles
Old Jan 17, 2008 | 02:48 PM
NWAF-150's Avatar
You cant trim fender wall. It hits on the backside of the front fender when cranked. also thats why i said i will mill it down but i need a number to start with.
Old Jan 17, 2008 | 03:08 PM
DIHLON's Avatar
I believe the 2" is 1 5/8" and the 2.5" is 1 3/4". That's what the Autospring instructions say anyways.
Old Jan 17, 2008 | 07:22 PM
CRJ Pilot's Avatar
NWAF-150, I sent you an email a while back asking you about the Skyjacker lift. Thank you for your reply! I finally got it on. I planned on cramming 37's, but failed miserably. So I was forced to put a 2 inch spacer to make the 37's work. I know with your lift, you will be fine putting a 2 inch spacer on. My angles arent nearly as bad as what I have seen on here with people stacking spacers on other lifts. My pic makes the angles look steeper than it does in person. My camera angle may be to blame! If I felt like going out in the snow and taking another pic with a -5 windchill, I would... This one will have to do for now!
