Sponsored by: CARiD
6 inch lift..what to do with a leveling kit
Old Jan 16, 2008 | 04:58 PM
chip_in_nate's Avatar
i had a leveling kit but i decided to put a 6 inch lift on it instead cause the leveling kit didnt give me the look i wanted..4 wheel parts told me i cant keep it on...why not?what can i do with the leveling kit if anything?
Old Jan 16, 2008 | 05:12 PM
Dallasstars10's Avatar
Keep it on...
they told me that i couldnt with the suspension lift
Old Jan 16, 2008 | 05:13 PM
djh1121's Avatar
If it is a 2" keep in on, anything more don't do it.
Old Jan 16, 2008 | 05:16 PM
why did they tell me that i cant keep it on?
Old Jan 16, 2008 | 05:25 PM
Mikestyger1's Avatar
If you keep it on and it's more than a 2in kit then the cv angles will be way off. The angles may not be right on, even with a 2in or less leveling kit and that might be why they want you to take it off.
Old Jan 16, 2008 | 05:26 PM
JD790's Avatar
Sell it on eBay or list it here in the classifieds if you don't want it anymore.
A 2.5 leveling kit puts an extreme angle on the upper ball joint and cv shaft that could cause premature wear and/or failure. A 1.5" or 2" kit doesn't put such a severe angle on these items. If it is a pro comp lift using the huge spacers do not stack spacers at all!!!!
Old Jan 16, 2008 | 05:37 PM
07screw's Avatar
4wp will not stack any kind of lift together weather its a suspension lift
body lift or leveling kit
they will do any by there self but not together
with them being a nation wide corporation they just have to much liability {at least thats what they told me in the past}
Old Jan 16, 2008 | 05:44 PM
fiveoh108's Avatar
I put it on myself and had 4WP align my truck, they said they could not guarentee the alignment because of the spacer....also said that it would void my Fabtech warranty which i also installed myself, but i like the look and feel the 2inch is not that big of a strain perse, on the suspension.
Old Jan 16, 2008 | 08:59 PM
nooq's Avatar
if its a pro comp stage 1 lift which uses a spacer to achieve the lift, i wouldnt suggest doing it. Fabtech is another story...you can pull it off with that lift.
Old Jan 16, 2008 | 09:03 PM
f150monster232's Avatar
I have a 3in spacer on mine and my Cvs are fine i would keep it on if i were you
Old Jan 17, 2008 | 01:40 AM
chazf150's Avatar
Keep it on! I had a 2.5" on but the angle were to extreme. I`m going to try a 2" in the near future.
?Anyone out there need a AS 2.5" or trade for a AS 2" ?
Old Jan 17, 2008 | 10:20 AM
wandell's Avatar
What type of lift do you have?
Old Jan 17, 2008 | 11:03 AM
TN-F150's Avatar
How much you asking and how old is it? I am looking for one.
Old Jan 17, 2008 | 12:49 PM
the 6 inch suspension lift is a procomp...the leveling kit is a skyjacker, ive had it for 4 weeks but was only on my truck for 3...i will sell it for 100
