Sponsored by: CARiD
What do you think?
Old Jan 6, 2008 | 02:08 AM
mudpudler's Avatar
What do you think?
I am thinking @ adding a 6" suspension w/coilover. Price is not a big issue, I want to do it right the first time. 06 Screw 4x4 want to run 35x12.50x20's What should I be looking for?
Old Jan 6, 2008 | 02:28 AM
Dallasstars10's Avatar
why not a 6-8" lift if price is not your issuea nd you want to run 35's?
Old Jan 6, 2008 | 02:43 AM
mudpudler's Avatar
sorry i wasn't real clear the first time. Yes i am looking for a suspension lift.
Old Jan 6, 2008 | 08:31 AM
attworth's Avatar
It'll look real good. No reason not to if you have the money to spend. You'll probably wanna regear as well so factor another 1500-1600 to get front and rear done.
Old Jan 6, 2008 | 10:50 AM
f150monster232's Avatar
do a rize with kings
Old Jan 6, 2008 | 11:03 AM
wandell's Avatar
I'd suggest the Rize, RCD or Fabtech lifts.
Old Jan 6, 2008 | 11:23 AM
Barrett's Avatar
I agree with Wandell
Old Jan 6, 2008 | 01:38 PM
wxscpo's Avatar
I'd say go for it! If money isn't an issue then I'd suggest an 8" Rize. Once you lift it you'll always want to go bigger so as you say you'll want to do it right the first time. If you go with an 8" lift then you'll probably want to go with bigger tires because 35's will look small and if you do that then you most certainly need to regear as attworth stated. If you stick with a 6" lift and 35's then regearing is optional, although alot of us go ahead and do it. It all comes down to your budget and how much you're willing to spend.
Old Jan 6, 2008 | 07:31 PM
mudpudler's Avatar
Do you get that nose up/pre-runner look from the Rize like some of the other lifts wind up looking?
Old Jan 6, 2008 | 07:36 PM
attworth's Avatar
Most lifts I've seen on here do that. Simple solution is either bigger blocks, AAL, or a custom set of rear springs from someone like Deaver
Old Jan 7, 2008 | 01:21 PM
mudpudler's Avatar
RoadArmor
Anybody familiar w/ Road Armor bumpers?
Old Jan 7, 2008 | 01:32 PM
Bryndon's Avatar
The coilovers should give you control over nose up or down, by adjusting them. I personally prefer the tail up a little (load it and it's level). Running a 6" SkyJacker, very happy with it. It's a stock style coil over setup. 6" front lift, 4" springs in back. Leaves me about an inch nose down.
I know a little about Road Armor - very heavy and very heavy duty. Great choice.
Old Jan 7, 2008 | 01:51 PM
mudpudler's Avatar
Question
Is the weight of Road Armor bumper too much for the front end once the lift is installed?
Old Jan 7, 2008 | 02:02 PM
CRF250rider1000's Avatar
I would think it wouldn't be a problem with the adjustable coilovers. Just crank them up a little more and it will even it out
Old Jan 7, 2008 | 07:05 PM
mudpudler's Avatar
Thumbs up
Thanks for the help guys!
