Sponsored by: CARiD
Simple Suspension Question
Old Dec 31, 2007 | 09:42 AM
hhottrod's Avatar
Question Simple Suspension Question
I have a 2001 F-150, 5.4L, 4x4, Extended Cab.
Occasionally (5-8x/year) I load it up pretty good with manure, sand, mulch, etc. When I needed new tires I got LT tires D rated. I am looking into some suspension upgrades. All of the upgrades I see have the disclaimer "never load your truck above the manufacturer recommended...".
Question: What is the limiting component of the payload of my bed?
If I upgraded my tires and my suspension, would it be my axle? The frame?
Another way to ask this question is: What makes a F-250 capable of a heavier bed payload?
Thank in advance.
P.S. I know that some of you are in love with "Air Lifts". Recommending them is thoughtfull, however it does not answer the question asked.
Old Dec 31, 2007 | 11:33 AM
KansasJoe's Avatar
springs and axle...you either need to add a leaf or put air bags on
Old Dec 31, 2007 | 12:21 PM
hhottrod's Avatar
Thanks Kansas Joe
So let's say I add A Hellwig LP-25 or SuperSpring set up. What could I realistically put in my bed before I put my axle in jeapardy?
Old Dec 31, 2007 | 04:33 PM
KansasJoe's Avatar
Look on your door jam and it will give you the gawr which is what the axle is rated at if the weight is evenly distributed. It will also give the gvwr which is the max your vehicle should way including payload so subtract your vehicle weight from that number to get your payload. If you get into towing numbers then you get into gcwr which is combined weight.
