Sponsored by: CARiD
5100 Bilstein Ride
Old Dec 23, 2007 | 09:58 AM
VAUGHN22's Avatar
5100 Bilstein Ride
My front suspension is stock as of now.
I seem to feel alot of the road through the steering wheel. Dealer said everything is tight.
I'm installing the AS 2.5 and possibly 5100's.
My question is, do the Bilsteins give you a softer
ride than stock?
Thanks in advance..
Old Dec 23, 2007 | 10:05 AM
ScottFF00's Avatar
I would imagine like most aftermarket shocks, they will feel more stiff and firm.
On a side note. Where is the cheapest place people have found for Bilsteins??
Old Dec 23, 2007 | 10:16 AM
Bill_T's Avatar
Bilsteins
If you put the 5100's on you truck that is the only leveling kit you need. You cannot use the with spacers unless you use them in the stock position. The Bilsteins are a little firmer than stock and give a very controlled ride. Check out my pic's for what the end product looks like. I only have the Bilsteins installed in the 2" position, no other lift at all.
Old Dec 23, 2007 | 11:05 AM
Maxout05's Avatar
ride than stock?
Thanks in advance..
I am in the same exact decision boat as you, down to the steering problem!!
Old Dec 23, 2007 | 11:25 AM
bone79's Avatar
hey bill t, i have the procomp stage 1 lift, can i still use the bilsteins in the 2" position? thanks
Old Dec 23, 2007 | 03:55 PM
Bill_T's Avatar
Bone, provided that you are using the stage 1 kit and nothing else, you can probably get away with it. Your control arms should sit fairly level with the pro comp kit so adding the bilsteins in the 2 in. position would be about like adding them to a stock truck. Just be sure to check clearances and ball joint angles when your done.
Old Dec 23, 2007 | 04:04 PM
Bill_T's Avatar
Bilsteins
Scott, I ordered my 5100's from Top Gun Customs, they were the cheapest I found. $389 delivered to my front door!
Another place to check is the Shockwarehouse,
http://www.shockwarehouse.com/index....cted_year=2005
Old Dec 23, 2007 | 04:39 PM
ScottFF00's Avatar
Thanx Bill. Good looking truck also.
