Sponsored by: CARiD
Spindle Replacement
Old Dec 21, 2007 | 02:46 PM
daculatruck50's Avatar
Spindle Replacement
I have a 2004 NBS Reg. Cab F150. I have a 2.5 AS on right now at a pretty severe angle. I want more lift without buying a full lift. I realize that the bad ball joint angle is the only thing holding me back from getting a little more lift. I was thinking about putting a 4WD spindle on my truck because they are 2" taller than the 2WD sprindles so i could add the 5100's and still have ok Ball joint anlges. It would kinda be like a factory 4WD with a Auto Spring on it. But i just dont know if i could make a 4WD spindle fit on my truck because i have no CVs.
What if i got a fabtech/procomp spindle from one of there 2WD lift kits. I would have a bigger spindle letting me go a little higher with the 5100s and i would have good ball joint angles and the spindle would be made for a 2WD.
What are yalls thoughts???
Thanks,
Trent Kammerer
Old Dec 25, 2007 | 04:27 PM
Please i need help. Would it be possible to put either factory 4x4 spindles or a 4x2 procomp/fabtech 6" lift spindle on a factory 4x2 04 NBS f150? I want to correct the angle my 2.5 spacer and 2" 5100's will create. If i can get the bigger 4x4 spindle and make it work on my 4x2 it would be awesome!
Thanks!
Trent Kammerer
