Sponsored by: CARiD
Bilstein 5100s and Level Kit
Old Dec 5, 2007 | 07:36 PM
attworth's Avatar
Originally Posted by nooq
Go with the adjustable shock and eliminate your leveling kit. it is not possible to run a leveling kit with your shocks adjusted for lift.
Decided to start a new thread. Does this mean that you cannot use a leveling kit with Bilstein 5100s?
Old Dec 5, 2007 | 07:58 PM
Bill_T's Avatar
You can use the 5100's and a leveling kit, but you will have to use the 5100's in the stock position, not the lifted position. You cannot use both lifts due to not having enough room to install both of them and even if you did by some miracle the ball joint angles would be so severe you would destroy your ffront end.
Old Dec 5, 2007 | 08:19 PM
attworth's Avatar
Ohhh... I gotcha.. Well that sucks. I want another inch or two. Guess I gotta drop the dough for a real lift.
