Pro Comp stage 2 kit help asap
I just dropped off my truck at the shop to have the pro comp stage 2 kit put on and some 35 nitto mg. the guy said that the tires would look small bc the coilovers are huge and actually give you more than a 6 inch lift. any truth to this? is my truck still going to be leveled? thanks
Yes, I had this problem as well.
The 4 Wheel Parts in Plano, Tx told me I would not be able to fit anything larger than a 35" tire. They were WRONG. I know I could have fit 36" tires, but it still looks great with the 35.
Also. The rear is messy the way the blocks are stacked. Pick up that add a leaf off nooq if you have the money!
Originally Posted by nooq
the coilovers are almost a 1" - 1.5" larger than there spacer they use on the standard pro comp lift. if your a 2wd, i doubt you will sit level, probably higher in the front, because the pro comp kit only comes with a 3" block. if you're a 4wd you will sit closer to level but no completely level, that being because they stack the 3" block ontop of the already existing oem block ford puts on. if you're a 2wd, get a 5" block for the rear, or get a 2" AAL. i got a brand new AAL for sale if you need it. 110$ + shipping.
