Sponsored by: CARiD
need help fast!! please help!!
Old Nov 20, 2007 | 12:48 PM
TonkaTruck33's Avatar
im adjusting the bilstiens and im all done the only problem is that im trying to tighten the upper control arm ball joint and it seems to move with the bolt. it did this on the other side but only for a little bit. what can i do to tighten it up easier?? need help asap. i go in to work at 2 and i still need to take it to get aligned.
Old Nov 20, 2007 | 12:55 PM
jiggle's Avatar
You have to put pressure on the bolt up toward the control arm. Sometimes you can put enough pressure on it by hand, but most likely you'll have to use a clamp. When pressed in, the ball sort of locks so it won't spin.
Old Nov 20, 2007 | 01:01 PM
FoMoCoFan17's Avatar
Also, the alignment may not be off that bad, if at all. After installing my coilovers I didn't need one.
Old Nov 20, 2007 | 01:19 PM
well after installing one.. i think i will need one. ill check it out when i drive it. ok so i need to put presure upwards then correct?
Old Nov 20, 2007 | 01:25 PM
jiggle's Avatar
Yes. It can be tricky, but you'll have to find a way to push the ball up into the socket while tightening it. Sometimes you can get a clamp on it, sometimes you have to use channel locks, and sometimes you can use a jack and the weight of the vehicle to do it. I'm not familer with the new body style so I don't know exactly how to do it on yours.
Old Nov 20, 2007 | 01:36 PM
wow that worked thankz jiggle.
Old Nov 20, 2007 | 03:16 PM
Impact9's Avatar
Ok now you gotta update your pics!
I'm going to be adding a body lift myself here in a couple months. Did you do your body lift yourself? If so, how long did it take and was it hard?
Old Nov 20, 2007 | 06:44 PM
no i didnt do it my self and the person who did told me that from now on they were gonna charge a lot more to install, said it was a hassle. keep in mind this person took about 4hours to install my suspesion lift. the shop charged me 600. hey impact i forgot to ask u.. can u take a pic of how that skid plate is mounted? i wanna get one but i dont know if it will fit with my body lift.
Old Nov 20, 2007 | 08:04 PM
Impact9's Avatar
I didn't even think about that! I'm pretty sure it won't work since the mounting spot for the front plate is connected to a bracket that mounts on the lower valance bolts. With the bumper moved up it's going to be too short and angles way off to match up.
Old Nov 20, 2007 | 08:17 PM
wow and i need one asap cuz i hate that big gap. do u think theres any way that i can add some other peace to make it fit? without looking home made? im thinking of just buying it and messing around with it. but if it dosent look good then im screwed.
Old Nov 20, 2007 | 08:24 PM
Impact9's Avatar
yea not a fan of the gap myself. You might be able to use some stainless diamond plate and make a 3" drop for the mounting bracket to attach to. Then use some nice looking hardware to keep it clean. Or get the skid plates made at a machine shop. Should be real easy with a descent size bender. No more than what a skid plate is I'd make one myself. \
Oh while I'm thinking of it have you noticed any suspension knocking sounds since installing your 5100's? Sounds like I got something loose every time I hit a bump there's a dull knock. Maybe something else in the lift is working loose but damn is it hard to find cause every thing is still pretty tight.
Old Nov 20, 2007 | 08:31 PM
im gonna ask my uncle to see if he has some sheet metal at his work, i might go that route and make one. ill post pics if i do make one.
