Sponsored by: CARiD
CST Lift?
Old Nov 13, 2007 | 03:59 PM
supachargd2k5's Avatar
CST Lift?
I have been reading and thinking about which potential lift i want to do in the next 6 months or so and i was thinking about going with the CST 8". If i run the 8" with some 22" x 9.5 Rockstars and 37 x 13.5 x 22 Toyo MT would i have any major rubbing issues? Is there anyone on here running a similar setup? The lift comes with the fox coilovers and resevoirs in the rear and is about $4300, is it really worth the money or would it be just as good to go with the procomp stage 1 with the 2.5" leveling kit? Sorry for so many quiestions, thanks.
Old Nov 13, 2007 | 04:35 PM
wicked0ne's Avatar
I would ditch the FOX and go with Sway A Way. I origionally was going to buy a CST but they do not make many of the them and there is a 12 week back order. CST mainly make lifts for 250 and 2500. So I went witha black powder coated Rize. Also the CST requires specific BS less than 5 or plan on useing spacers. The rize since is uses a curved spindle you can get a way with uses 5+ BS. The wheels that I wanted were 5.04 bs so that made the decision easy. I have King's on mine but after getting screwed by King I can not recomend them.
Old Nov 13, 2007 | 05:13 PM
Hash278's Avatar
If you considering a spacer on top of a lift kit dont get the procomp lift cause they already use a spacer up front and its not good to stack spacers. Get the basic Fabtech and put the spacer on that.
Old Nov 13, 2007 | 05:14 PM
Im really liking the 8" rize lift kit and if im not mistaken it doesnt come with shocks. What would be a nice quality shock to use on this lift?
Old Nov 14, 2007 | 08:41 AM
wicked0ne's Avatar
CST dosen't come with shocks either. The rize does come with rear shocks and spacers for the front if you wanted to use your shock coil overs. I used kings on mine but they are the most expensive. You can use the FOX one SAWs and save $500 to $600. I got my kit with lines and Add Aleaf, powder coated black and Kings all the way around from Truck Toyz for $5600. If you didn't want it powder coated you could get it ffot $5000. If I had to do it over I probably would have went with the SAWS.
Old Nov 14, 2007 | 08:53 AM
Thanks for the help guys
