1 more inch in the rear
Originally Posted by nooq
those shims are built into the leafs themselves, i tried removing them with a tap and sledgehammer and they wouldnt budge. they did give me a honest inch of height in the rear. that is why i needed to crank my coilovers up to get the truck to sit level. the a$$ end was up higher then the front with the coilovers uncranked.
http://www.explorerprocomp.com/PDFs/is/52700.pdf
Mine are just bolted into the leaf pack. Above is the install from the website.
Nooq did you buy your truck used? You may be able to unbolt them like in the install above.
