Sponsored by: CARiD
leveling kit
Old Oct 3, 2007 | 05:30 PM
scrap08's Avatar
leveling kit
I cant seem to find any 2 or 3 inch leveling kits for my 2001 F150 because it is 2WD. All of the ones I have seen require the truck to be 4X4. Does anybody know any better websites?
Old Oct 3, 2007 | 06:21 PM
Ruthless1's Avatar
http://www.4wheelparts.com/CT1.aspx
Old Oct 3, 2007 | 08:55 PM
wandell's Avatar
Daystar makes 2 inch coilspring spacers for your truck. If you go taller than 2 inches (with a spring or spacer) you will have to have longer upper control arms to get the alignment withing specs. You could also instal 3 inch lift spindles.
Old Oct 3, 2007 | 09:00 PM
scrap08's Avatar
which look better, leveling kit or lift spindles?
Old Oct 4, 2007 | 08:42 PM
wandell's Avatar
Personal preference. THe spindles will increase your front track width. Personally, I'd combine the two. Bigger is better.
Old Oct 4, 2007 | 09:17 PM
keith_bennett's Avatar
Originally Posted by wandell
Bigger is better.
When in doubt, go bigger. And bigger is better.
Old Oct 4, 2007 | 09:26 PM
wernerslostblue's Avatar
1.5 or 2.5 and you require control arms at 2.5.
http://www.autoanything.com/suspensi...0A2172217.aspx
i installed the 1.5's it levels it out perfectly. easy to do yourself too.
Old Oct 5, 2007 | 04:30 PM
scrap08's Avatar
why do you see some trucks with there tires sticking too far out, what is that from?
Old Oct 5, 2007 | 04:32 PM
CANES676400's Avatar
its from the backspacing on the wheels
Old Oct 6, 2007 | 09:54 AM
wandell's Avatar
Also, a lot of lift kits for 4x2's, including spindles, increase the front track width a couple of inches.
Old Oct 6, 2007 | 01:37 PM
scrap08's Avatar
does it happen with body lifts?
Old Oct 7, 2007 | 10:29 AM
wandell's Avatar
No.
