Sponsored by: CARiD
Hey CHAZf150!!
Old Sep 6, 2007 | 07:21 PM
thorherc67's Avatar
Hey CHAZf150!!
Can i get some pictures of your front ball joint angles and some other angles of your front suspension i am getting the same setup as you but want to make sure nothing gets messed up. How do you like the ride and how is the truck offroading??? I like your truck nice work!!
Old Sep 7, 2007 | 12:45 AM
chazf150's Avatar
? Is yours a 4x4 , My`s 2x4
I started with a basic fabtech 6". 3 month later had to replace lower ball joints ( due to normal wear ). Replaced ball joints And put my 2.5" as back on. Angles don`t look to bad. I`ve seen worse. It`s been 4 months now and so far no issue`s. This is my daily driver, about 100 miles a day.
The ride did get stiffer And the turn radius stinks. It`s not to bad on the highway. So I`m please with the ride. As far as off roading, This truck doesn`t see much dirt. I have chevy sub 4x4 for that.
Here`s some pics
B4
After
B4
After
Old Sep 7, 2007 | 07:49 PM
thorherc67's Avatar
hey thanks alot i have a 2x4 so i guess my angles will be the same as yours. But your angles don't look bad at all so i guess this is what i will be doing Your truck looks really good and i hope i can get everything to work out. what do you have as far as the lift in the back??
Old Sep 7, 2007 | 10:32 PM
clar's Avatar
One spring has the rubber worn off of it in the middle what happened there?
Old Sep 7, 2007 | 11:47 PM
chazf150's Avatar
thorherc67
5" rear blocks.
In the near future I`ll be lifting the rear. Since i put the as back on.The rear sit about 1.5" lower
If anyone out there can help. Whats the best rr aal and will my shocks work .I originally started off with 2" blks. ???
clar
bumped the spring on the lower arm while pulling it out.
Old Sep 8, 2007 | 12:02 AM
thorherc67's Avatar
chazf150 Thank you very much for the information it will help out alot and i am going to do the same lift setup as you in about 2 months or so, I CAN'T WAIT lol and when you get that aal in there put up some pics because i want to see how it will look. again thank you
Old Sep 8, 2007 | 01:54 AM
chazf150's Avatar
Goodluck
