Sponsored by: CARiD
Getting an extra inch from the front end (lowering)
Old Sep 5, 2007 | 11:24 PM
ride-red's Avatar
I just installed a set of DJM 2" coil springs and Nitro Drop 2 shocks. The rear received hangers and shackles. The drop ended up leveling the truck out almost perfectly front to back which makes the front appear to be a bit taller. I would like to get another inch out of the front end to give it a slight rake. Could I cut an inch off the front coil without giving up the ride or should i source a set of 3" springs and replace the DJM's that i currently have?
Old Sep 6, 2007 | 10:12 AM
wandell's Avatar
There are mixed opinions on cutting coilsprings, but I've seen CHip Foose do it. I think it's like a lot of things, it's fine if you don't go crazy with it.
Old Sep 6, 2007 | 11:31 AM
ride-red's Avatar
So to cut the coil spring I would measure the total length of the spring uncompressed, subtract an inch and cut at that point on the coil?
Old Sep 6, 2007 | 07:54 PM
5150f150's Avatar
no...dude to cut springs you have to do it slowly and in small increments measure around the circumferance.i'd start with 3 inches first. also dont use a tourch. use a sawzall or hacksaw as the heat from a cutting wheel or tourch will change the rating on the coils. heat is the enemy
