Sponsored by: CARiD
Bumpy Ride
Old Aug 28, 2007 | 10:34 PM
firemannelson37's Avatar
Bumpy Ride
I have a 2006 f150 supercab 4x4 with a front leveling kit, I have noticed that the ride has gotten really bad, I mean you can feel evey little bump in the road. I know its a truck and its not supposed to be a luxury ride but I went for a ride in another 06 f150 and it was a much much smoother ride. Is there anything I can do to make it a smoother ride? Thanks
Old Aug 29, 2007 | 08:08 AM
clar's Avatar
What air presure are your tires set at I rum my 35s at 35Lbs the other day I set them at 40 was a much harder ride.
Old Aug 29, 2007 | 09:36 AM
Bryndon's Avatar
Tire pressure for most tires should be 40-45, check that first, because my stock tires are max pressure 80psi... if someone moved you to full pressure, that would hurt. Also, depending on the miles and usage, worn out/broken shocks can hurt too.
Old Aug 29, 2007 | 03:09 PM
I have 6 month old 33in BFG a/t's, truck has 23000 miles on it.
Old Aug 29, 2007 | 03:31 PM
tg150's Avatar
I've got a leveling kit on mine and have had no change in the ride. 23,000 miles your shocks are probably shot and the 33's prob sped up the process..From what i hear and read 15,000-20,000 miles tops after that there junk . Get Bilsteins. How many miles were on the other 06 you drove in.
Old Aug 29, 2007 | 03:46 PM
normal tirepressure is 35-40, and you should never see maximum tire pressure for any reason, its just not safe
Old Aug 30, 2007 | 04:43 PM
hutch5.4's Avatar
If you were to get new aftermarket shocks would they last longer than the stock shocks?
Old Aug 31, 2007 | 11:03 AM
stlhrse's Avatar
mine's doing the same thing. It's an 05 FX4 with 24,800 on it. Shouldn't they be covered under warranty though? I really don't want to drop $150.00 on aftermarket shocks if I can get replacements under warranty that will last another 10,000 at least.
Doug
