Sponsored by: CARiD
T/bar adjustment
Old Aug 19, 2007 | 08:45 PM
birdog's Avatar
T/bar adjustment
Ok, I cranked up my t/bars on my 03 SC F150. There was a 1 inch difference between the driver side and the passenger side before I started. I turned one side 5 turns and the other side 2 turns to get the front end leveled out. Now there is only a 1/4 inch diff between the two sides. Does anyone have any problems with turning one side 5 times and the other side 2? Or should I back one side off 3 turns? I did notice the adjustment bolt is now identical as far as the same number of threads showing below the pin. It was not before I started. So, I guess my question is; 1) should I turn both the same no matter what they measure out at? or
2) Level both sides and don't worry about how many turns I have to make to get it there.
Old Aug 19, 2007 | 10:19 PM
ross2388's Avatar
2) Level both sides and don't worry about how many turns you have to make it level. The amount of turns doesn't matter. When I did mine, I think I had like 4 for the passenger and like six for the drivers side.
Old Aug 19, 2007 | 10:45 PM
wandell's Avatar
Don't forget to get an alignment.
Old Aug 20, 2007 | 08:25 AM
birdog's Avatar
New tires and alignment today. Thanks guy's!
