Sponsored by: CARiD
Leveling out with spindles
Old Aug 19, 2007 | 03:55 AM
andrewc_11890's Avatar
I have an 03 2wd and im putting a 3 inch lift spindle on. What size block would i need for the back to make it sit level? 1 inch?
Old Aug 19, 2007 | 04:07 AM
Bighun's Avatar
I have the same truck, though I don't know your answer, I was wondering if you are just doing spindles or if you need to also do the shocks and springs. I saw a couple auctions on ebay for our truck and they are selling 4 shocks, spindles for front and blocks for the back. Go to the site and type f150 lift and you'll see them. I saw some around $400 but didn't have a brand name shock that I;ve heard of.
Steve
Old Aug 19, 2007 | 04:31 AM
Probably the doetsch tech ones, from suspension max. I'm getting some spindles from a friend, so im wondering if i need a block too? Also he says all I need is the spindles and all my oem stuff can be re used. is that true?
Old Aug 19, 2007 | 09:48 AM
wandell's Avatar
Yeah, you can use all of your oem stuff.
I'd suggest parking your truck on a level surface and jacking up the front end 3 inches. Then decide if or what size block you need out back.
