6" lift questions for my FX4
Finally decided I think I want to lift my 04 FX4 6". I've been searching around here and think I narrowed my choices down to either the Fabtech 6" or the Pro Comp 6". I plan to upgrade to Traction Bars and a Skid Plate after the initial investment.
Anyways, heres the questions:
I currently have 295/75/17 Nitto's. Would these look to small with a 6" lift? I plan to upgrade to 35's when these wear out? This one is purely cosmetic.
The bigger question I have is:
Is there a big difference between going with the coilovers or spacers? This is a mostly street driven truck, that serves as my hunting/tow rig for my Jeep XJ that I use for the real offroading.
I dont mind a little rougher ride, and I'm more concerned if the spacers affect durability or reliability.
Also, is there anything not included with the kits above that should be addressed?
NEW Question: Will factory 17" rims work with the Pro Comp kit?
Thanks,
Brian
Thanks,
Brian
I think that you'll find that 295's will look small after you put on a 6" lift.
As for the coilovers or spacers. I have the procomp with the spacers. I have no complaints about the handling or ride but I still wish I had gotting the coilovers now just because I think it would look about 100 times cooler then the spacers do.
As for the kits, I know the procomp included everything but there are 6 holes in each spindle (3 front and 3 back) that are not tapped, so you should be prepared to tap them yourself before you do the install.
I've posted this before but here it is one more time;
my lift install
my lift install
Are you running 35's? Also, what size were your stock tires in the photo's?
I was thinking the same thing at first, although, according to a converter I found here: http://www.rockcrawler.com/techrepor...&Submit=Submit
A 295/75/17 is pretty much a 34" tire. I've seen one or two pictures with 315/70/17 which is also pretty much a 34" tire, that dont look that bad. Since most people run 35's I'm trying to decided if a 34" tire would really look that much smaller.
I believe this truck belongs to Beaver Tricks on this forum. According to his profile his truck has the 6" Fabtech with the 315's.
And, obviously the fact that I can upgrade to bigger tires later keeps nawing at me.
Thanks for the info and write up!!,
Brian
Brian
Personally if your truck is going to be driven strictly on pavement I wouldn't spend the extra money on expensive coilovers. From what I saw online the Pro Comp 6" lift with spacers is slightly cheaper than the Fabtech lift, but I think the Fabtech lift is worth the slightly additional cost. If you go with the Pro Comp spacer lift and decide later you want to add a leveling kit for an additional couple of inches of lift you won't be able to because you'll already have a spacer stacked on top of the coil. With the Fabtech lift you'll be able to do this with no problems.
Since you're a 4WD truck I'd think you'd want a 35" tire at a minimum, but if you already have the 34's then stick with those and upgrade when you need to purchase new tires.
Thanks for the info. I found this truck while searching for a setup similar to what mine might look like.
I believe this is Hash278s truck, which I think is a clean looking 1/2 ton!
According to his specs he's running a 6" Pro Comp and 33" tires. To me, that truck does not look to bad with 33's. I think I will be alright with my truck and 34's until I make the move to 35's.
One more question before I go ahead and order from some where, will factory 17" rims work with the Pro Comp kit? This is the last piece of the puzzel before I order.
Thanks for the info,
Brian
Brian
Your Nitto 295/70-17's are basically a 34x12.00-17 tire, so I think they will look ok with a 6 inch lift. I'm not sure if you will be able to use the oem wheels with the Pro Comp lift. I'd contact them and ask.
I use the stock rims and 35"'s on my 04 with 6" PC lift. I needed a grider to grind away about 3/16" from the supplied A-arm for tire clearence at the top inside next to the tire. Only on the driver side.
