Unidentified vibration
I drive a 2004 F150XLT, 4wd, auto trans, electronic 4wd.
Sometimes on a hot day, after the truck has been parked for hours, I'll be driving along, 30-40 miles an hr, and the truck will start shaking, like a front end vibration. I've checked the lugnuts, the tires are balanced, letting off the gas doesn't change the vibration, slipping the trans into neutral doesn't stop it either.
When I apply the brake, the shaking is more pronounced, and when I release, it returns to the previous level of shaking.
I pull over and stop, and when I take off again, the problem has cleared.
The last time it happened, I switched to 4wd. It took a couple of minutes before I could get it back to 2wd.
I suspect a faulty 4wd solenoid or similar problem.
The dealer (Lakewood Ford, Lakewood CO) can't find any problem. You know the drill- when the mechanic test drives the truck, it drives just fine.
Does anyone have any ideas? Anyone heard of this problem before?
All replies are welcome.
Thanks,
Barry
Thanks,
Barry
Thanks,
Barry
Thanks,
Barry
