Sponsored by: CARiD
Lift Issues
Old Aug 16, 2007 | 07:18 AM
dirtybeer05's Avatar
Lift Issues
Just put on my new rancho 4x2.5 lift and and not exactly happy with it. First off it now sounds like something is loose it the front differential when i hit bumps it clanks around! I know it didn't do this before, and the housing doesn't seem to be moving, just the drive axle's are. and my second gripe is the ride. I got the RS9000XL shocks and i feel like i'm gonna get sea sick. I do have the rear shocks mounted upside down, but i don't think this could be it. And i can't even find a guide to tell me which way to adjust the shocks since they didn't come with one cuz there seems to be no arrow or notch on the shock to tell you where your adjustment is set! PLEASE HELP! Thanks
Old Aug 16, 2007 | 09:36 AM
Copenhagen848's Avatar
Is it too stiff or too soft? Whichever number setting you want should be turned to the top of the **** if that makes sense. 1 being the softest. If your rears on on upside down, then the setting you want should be to the bottom. Not really sure about the clank you are hearing, did you install the lift yourself or have a shop do it?
Old Aug 16, 2007 | 09:52 AM
lift
I put it on myself, but didn't have any problems. did your truck have the rockin problem?
Old Aug 16, 2007 | 10:33 AM
No, I leave my shock settings at 1 for around town and switch them to 5 if I go off road at all.
Do you mean you are rocking from side to side? If so, stiffen up your settings and see if that helps at all.
Old Aug 16, 2007 | 10:56 AM
rocking
I'm not really rocking side to side. its really front and back! Def. frustrated with that and the noise though!
Old Aug 16, 2007 | 11:05 AM
After you lowered the truck back on the ground and the coil springs compressed from the truck's weight, make sure you check to see that the shock bolt/nut that sticks out through the top of the strut is tightened down all the way. I noticed that after I lowered my truck onto it's own weight, I had to tighten up this nut quite a bit more. Just a thought....
Old Aug 16, 2007 | 11:43 AM
baja150's Avatar
You must have not tightened something in the front end. Go back over all the bolts and make sure everything is tight. Don't forget about the 3rd bolt on the top of the front axle.
I put my own lift on and had a clunk sound coming from the front end and it turned out I forgot to tighten the nuts on the sway bar end links.
Just go back over everything. Even if it looks tight, double check it to make sure.
Old Aug 16, 2007 | 08:24 PM
Alright!!!
Thanks guys, the nut for the spring compression was it! Now i'm shi*tin in the weeds! Trucks looks and rides good now my Pro-comp wheels and **** Cepek tires just need to get here!
Old Aug 16, 2007 | 08:49 PM
FoMoCoFan17's Avatar
What Pro-Comp's did ya get?
Old Aug 16, 2007 | 08:58 PM
oops
In my excitment i said the wrong wheels. I wet with moto metals, black with rivets. i really want the **** cepek dc-1 black or the earnhart AR Cannons with black, but couldn't get either of those! I'm def. excited to get my wheels though!
Old Aug 16, 2007 | 09:36 PM
O.K. Good. Ya'll keep buying up those MM's. Stay away from the Pro-Comp ####'s
Old Aug 17, 2007 | 12:08 AM
Good deal, glad to help Make sure we get some pics!
Old Aug 17, 2007 | 02:47 PM
Grishnak's Avatar
I love my pro comps, like em better than the bfg's i had thats for sure.
Old Aug 17, 2007 | 05:10 PM
051fdrof's Avatar
The DC-1 weren't available?
