Sponsored by: CARiD
3'' Body lift question
Old Aug 12, 2007 | 06:42 PM
N2BNDVS's Avatar
If I put on a 3'' body lift on my 97 F150 4x4 what the biggest size tire I can run? Any help would be most appreciated.
Old Aug 12, 2007 | 06:45 PM
dondiesel444's Avatar
I have 315/75R16's on 16x10 wheels on my truck with a 3" body lift, check my pics. anything bigger wouldn't work...
Old Aug 12, 2007 | 06:46 PM
JMC's Avatar
JMC
25 Year Member
With or without a lot of rubbing? J/K If you crank the t-bars you should be able to run 35's.
JMC
Old Aug 12, 2007 | 06:55 PM
N2BNDVS's Avatar
Thank you! So you're tires are about a 35x12.50 right? I'll definitley check out the pics, do you tires stick out from the fender? Thanks again.
Old Aug 12, 2007 | 06:59 PM
N2BNDVS's Avatar
Hey Don, I saw the pics and I saw the fender shot, I think I'll be doing a similar setup on my truck.
Old Aug 12, 2007 | 10:20 PM
wandell's Avatar
Yeah, you can fit 35x12.50's on 10 inch wide wheels with 4.5 inches of backspacing. You will have to trim the front bumper's lower plastic valance.
Old Aug 12, 2007 | 10:53 PM
97f1504x469's Avatar
thats the exact same setup i have on mine with a 3 inch body lift and its also a 97'.(31575r16)
