Sponsored by: CARiD
Couple leveling kit questions before I pull the trigger!
Old Aug 11, 2007 | 10:41 PM
swishbish33's Avatar
I am about to go about purchasing and installing a leveling kit and BFG 33" tires on my '05 2wd Screw w/ the 17" mach. aluminum wheels. I've read these forums and searched, and there seems to be different opinions on these questions, so I thought I would ask them myself so I don't burn my money!
1. If I want the truck to sit level, is a 2" leveling kit enough for a '05 2wd Screw w/ the 17" mach. aluminum wheels? I've read some reports on here that says the 2.5" kit makes the front higher on a 2wd while others have said it doesn't. I definitely don't want the front higher than the back as I don't like the look.
2. Do either the Daystar or Auto Spring kits change the factory ride?
3. Are there issues with the Daystar considering that you must disassemble the strut to install it and that it is made out of plastic?
Thank you so much for your time and answers!
Old Aug 11, 2007 | 11:53 PM
wandell's Avatar
Place a jack under the front of your frame on a level surface and measure the front wheelwell height. Then jack the truck up 2 inches and 2.5 inches and see which height you prefer. Every truck is a little different.
A leveling kit should't change your ride.
The one piece kits like the Autospring are much easier to install because you don't have to take the coilovers apart. However there is nothing wrong with the design or durability of the Daystar kit.
Old Aug 12, 2007 | 07:44 AM
bluebeast06's Avatar
just put my 2 inch tuff country on two nights ago on my o6 extended cab its perfect now for the new tire
Old Aug 12, 2007 | 02:32 PM
shaka187's Avatar
for me, putting on the 2.5 made the truck level, however because the fender cut is higher on the front than the rear, the rear looks lower. i'm looking at an add a leaf for the rear...
Old Aug 12, 2007 | 04:32 PM
Shaka, is yours a 4wd or 2wd?
