Sponsored by: CARiD
ball joints
Old Aug 8, 2007 | 11:15 PM
MmmBuckles's Avatar
ball joints
what can i expect to pay for new upper and lower ball joints? i want to put on my spacer kit but i was told that i wont be able to get an alignment with out new joints. and how how would it be to install the joints?
Old Aug 8, 2007 | 11:25 PM
baja150's Avatar
You only won't be able to get an alignment if there is something wrong with your ball joints. Is that the case?
An alignment shop won't align a vehicle with worn steering/suspension parts. I think it may be the law.
Old Aug 8, 2007 | 11:26 PM
MmmBuckles's Avatar
ya. thats why i need new ones. im stilling running the ones that came with the truck, and they look pretty worn out
Old Aug 9, 2007 | 06:27 AM
1/2Breed's Avatar
All day reading in the search area on upper and lower Ball Joint replacement, just a hint.
Old Aug 9, 2007 | 09:12 PM
Yankee7985's Avatar
if you are handy with basic hand tools, you can do it yourself for about $225.00 for the parts. I just replaced the upper & lower ball joints, Inner & outer tie rod ends and the idler arm on my 01 expy and the total cost for parts was about $375.00. The local tire shop wanted $225.00 to replace just the idler arm and do an alignment. Dealer cost for all of the above would have been about $1600.00
Old Aug 9, 2007 | 09:14 PM
MmmBuckles's Avatar
ok. good, i think ill just replace the joints and put the spacers on there while i have everything taken apart.
Old Aug 10, 2007 | 07:27 PM
Yankee7985's Avatar
Don't forget the (2) camber kits for each side. You add these when you replace the upper control arm, if they are not there from previous alignment(s).
Old Aug 11, 2007 | 12:04 PM
mitch150's Avatar
I just replaced my lower balljoints yesterday. 1 pair of Moog balljoints: $76.00. Go to www.rockauto.com, they seemed to have the best price! As far as doing the replacement yourself, it's alot easier if you have some air tools and a compressor and a balljoint replacement tool(this is for pressing the new balljoints onto the lower control arms). Putting the new ones on can be a real bitch without a balljoint tool!! Job is pretty straight forward and shouldn't take too long if you have the right tools.
Old Aug 12, 2007 | 03:11 PM
Cynder's Avatar
here's one of the times that OEM sucks... make sure that the joints you get have grease fittings so that they can be serviced...
Ford's policy = they are greased for the life of the part...
