Sponsored by: CARiD
sway bars
Old Aug 8, 2007 | 04:51 PM
jsz289's Avatar
sway bars
I have a 97 f150 what do I have to do to get a rear sway bar on it?
will I have to mod anything?
the sway bar i have is off a 2000 f250 5.4L
Old Aug 8, 2007 | 10:13 PM
baja150's Avatar
What exactly do you have?
I'm not 100% familliar w/ the pre-current style F-150's, but you're going to need the sway bar, end links, end link bushings, axle mounts, and frame mounts, plus hardware.
Old Aug 9, 2007 | 11:58 AM
jsz289's Avatar
I bought all the parts from a wrecking yard I have all the hardware from the 2000 f250 I just want to know if I need to mod anything to get the bar to fit
it looks like the holes are pre stamped in the frame.
Old Aug 9, 2007 | 12:26 PM
jiggle's Avatar
I would assume that a sway bar from a 250 would not just bolt up to a 150. The frames and suspension from the two trucks are completely different. You'd probably have better luck getting one from an Expedition.
Old Aug 9, 2007 | 02:57 PM
jsz289's Avatar
I looked on alldatapro and the expedition has rear independent suspension so it wont fit
Old Aug 9, 2007 | 09:16 PM
jiggle's Avatar
Well then I guess one from an Expy won't work. Good luck.
