need some lift advise
howdy yall, ive got a few questions i have a 2000 f150 2wd reg cab long bed and i want to put in some sort of lift but i dont have alot to spend,i was warndin if i could put 3in body lift from PA and also a 2in suspension lift from rough country in it but i dont if it will work ,,,,please somebody help me out
Yes, you can combine the two lifts. The suspension lift is probably lift coils or coilspring spacers. I believe the limit with lift coils or spacers is 2 or 2.5 inches. If you go higher than that you have to have new, longer upper control arms to get the alignment withing specs.
a couple more questions
yea in the suspension lift its just front coil springs,,,so then you think it will work???its not goin to screw up the proformance,MPG or anythin like taht is it??? oh yea dose that mean i would aget a total of 5ins of lift??? thanks guys
A 3 inch body lift and 2 inch lift coils will give you 5 inches of lift. A 3 inch body lift and 2 inch coilspring spacers will also give you 5 inches of lift. They will not affect your performance, but the larger tires you install after the lift will. How much depends on your powertrain.
