Sponsored by: CARiD
new to this front suspension question
Old Jul 24, 2007 | 10:10 AM
tuff150's Avatar
new to this front suspension question, i put spacers in my front went up 2" then i put a 1.5" block in rear thought it would look good which it does but i wouldnt mind haveing the front level with the back now any ideas and how much would it cost thanks -mike
Old Jul 24, 2007 | 11:52 AM
Copenhagen848's Avatar
Are you asking about raising the front up more to make it level with the rear? If so, a suspension lift is probably what you're after. Those are around $2000 installed.
Or you could just put the stock blocks back in the rear and it will be level with the front.
Old Jul 24, 2007 | 12:10 PM
tuff150's Avatar
im talking about just bring the front level with the rear which is now an additional 1" higher then the front after i put the 1.5" block in. Ithere any way to get another inch including the spacer, so that would make 3" in the front. thanks -mike
Old Jul 24, 2007 | 12:35 PM
FoMoCoFan17's Avatar
If you stacked rear blocks you'll need a full suspension kit to get it right. Or take the rear block out.
Edit: You can get a 3" leveling kit but I would not go that direction. I had a 3" kit... not good. Save some money for a lift that drops the LCA's.
Old Jul 24, 2007 | 12:47 PM
Yep, Skyjacker makes a 3" leveling kit that includes new springs and shocks but it doesn't lower the LCA's so it puts pretty extreme angles on your ball joints, etc. You'd have to take your current spacer out before you put in a 3" kit. I don't know of any way to get just one more inch on top of your existing spacer.
Old Jul 24, 2007 | 12:50 PM
tuff150's Avatar
i have a feeling the truck may look better if the front was level with the back but i dont want the truck that high b/c i pull a trailer often and i dont want to kill my mpg. btw would it really cost 2000 for a 3"front suspension lift
Old Jul 24, 2007 | 02:32 PM
You can get the pro comp 6" for about 1200-1300
Old Jul 24, 2007 | 08:27 PM
wandell's Avatar
I'd just remove you current leveling kit and install a 2.5 inch Autospring leveling kit.
Old Jul 25, 2007 | 12:00 AM
A suspension lift kit is about $2000 installed, give or take a couple hundred depending on the brand and/or which shocks you get. There is no 3" suspension lift for the '04-'07s though, only leveling kits
Old Jul 25, 2007 | 12:10 AM
couldnt he do coil over lift?
Old Jul 25, 2007 | 08:22 AM
tuff150's Avatar
alright thanks how much does the autospring run?
Old Jul 25, 2007 | 09:26 AM
BlueSteel_05's Avatar
they range from about $85 to $100 on ebay..
