pics of 6 inch fabtech lift?
Originally Posted by bud8817
tantrum was the first trick i learned best thing to do is practice backflips on a trap for a while and get down spoting you landing, get lots of speed hit the wake then throw the flip make sure you are looking for the landing the hole way around its really easy to over rotate and end up have you back facing the boat if you get a go amount of pop. once you hit the wake throw you back arm up into the air and look over you back shoulder the air will catch you board and throw you around it take some good arm strength to pull you feet back under you. it takes some practice but if you can do back flips on a trap or even into a pool that helps alot to getting down spotting your landing and knowing were you are upside down..... that contest sound good to me ill check it out i really want to get into the contest thing im excited to ride this new board in about 4 hours i should go to sleep.
sorry bro, but, can i get a measurement from the bottom of your side mirrors to level ground??
