Sponsored by: CARiD
What kind of lifts are available for a 4x2?
Old Jul 7, 2007 | 08:17 PM
floridafordron's Avatar
I have a 2004 supercrew 4x2, and would like to know what kind of lifts are available for 4x2s. If you have any suggestions/pictures, please post them.
Old Jul 7, 2007 | 08:36 PM
Copenhagen848's Avatar
Fabtech has a 6" lift for 4x2s. Several members on here have them.
Old Jul 7, 2007 | 08:58 PM
GregAsk's Avatar
I too would like more of a complete list on this. I have found the as Leveling kits, skyjacker 3, and 6" lifts and the fabtec. but what kits are you guys running.
Old Jul 7, 2007 | 09:50 PM
wxscpo's Avatar
For 4x2 all you need to know is Fabtech.
Old Jul 7, 2007 | 10:57 PM
wandell's Avatar
Pro Comp also makes a 6 inch lift for 4x2's, but the Fabtech would be my first choice.
Old Jul 7, 2007 | 10:58 PM
ThumperMX113's Avatar
I'd suggest Fabtech too. But I'd try to find out if the RCD kits will work on the 2WDs, I'd go with one of those before anything else.
Old Jul 8, 2007 | 12:22 AM
chazf150's Avatar
Same here!
Old Jul 16, 2007 | 05:37 PM
Wes Blackwell's Avatar
I have the same truck as you. I was in the same boat. I would stay as far from Fabtech as you can. They're cheeeeaaap. Pro Comp is good, they use CNC casting so all there parts are made from one solid piece of steel. Fabtech uses welds...which can break. I'm going with CST Suspension. Much better quality. Pro Comp and Fabtech are just cheap generic lifts. They're fine if all you want is looks. RCD lift can be bought with shocks or not. Without shocks, it costs as much as a Pro Comp or Fabtech including shocks. So that says something.
Old Jul 16, 2007 | 10:41 PM
wxscpo's Avatar
First time I have ever heard anything negative about Fabtech lifts. What's your experience with a Fabtech lift? If you had one and it failed somehow ever think maybe you got the one bad apple out of the bunch?
Old Jul 16, 2007 | 10:46 PM
f150monster232's Avatar
It there anyway u could fit a rize on a 4x2...
Old Jul 16, 2007 | 11:56 PM
chazf150's Avatar
Same here. ?????
Always had fabtech on my trucks with no issues. ???????
Old Jul 17, 2007 | 03:58 AM
Prerunnin_Crew!'s Avatar
Fabtech Lifts!!
Fabtech lifts arent bad if going for looks, but if you want performance out of a 2wd lift i would go with CST. I have a 2002 Supercrew with a fabtech 7.5 crossmember lift and its ok nothing to brag about. Same travel as stock and even teh long travel kit from Fabtech is 2in. more travel. With the Fabtech lift you are very restricted on the types of shocks because of the shocks are stem mounted. If you are lookin to air out your truck then dont go with the fabtech id spend the extra cash and get the cst long travel kit. they both fit 35's and with 'glass fenders you can fit 37's. I never had any issues with the Fabtech lift just not content with it. Good luck!!
Old Jul 17, 2007 | 09:51 AM
EBROTEN's Avatar
Fabtech and CST are both really good kits but if your looking for performance I would look into the Camburg 7.0 Coilover Kit. http://www.camburg.com/04F150.html
