Sponsored by: CARiD
leveling kit to high
Old Jul 5, 2007 | 05:56 PM
07screw's Avatar
I had a 2.5 daystar leveling kit installed and now my front end is to high
checking it with a tape measure its about 1" difference
that maybe an incorrect way of checking because fenders are not symmetrical
some of you talk about 1.5 aal i think thats an add a leaf. Any one elese had this problem?
Or was my kit installed wrong ?2007 screw 4x4
Old Jul 5, 2007 | 09:02 PM
I've been having the Daystar 2 1/2" kit on for 2 yrs. on my '04 Screw, it has sat perfectly level since installed. The only difference is that the '04's sat a lot taller in the rear than the '07's. probably due to taller block's in the rear.
Old Jul 5, 2007 | 09:53 PM
07screw's Avatar
thanks for your input.so is it possible to be installed wrong?
I had a 2005 screw 4x4 with same set up it sat perfect
Old Jul 6, 2007 | 04:37 AM
N2OPONY's Avatar
I just installed the AS 2.5 and my front sits about .5 in higher than the rear, I still need to get the alignment done and break it in a bit. Hopefully it will grow on me or maybe once the springs settle it will level out. If not I'll add the AS rear block to it.
Old Jul 6, 2007 | 07:44 AM
07screw's Avatar
What size block is the as?
Old Jul 6, 2007 | 07:55 AM
Shane1's Avatar
It comes in 2.5" & 2" sounds like you should have went with the 2"er or just put the AAL in the rear and no worries....other than money
I have the 2.5 AS on mine and it sits level....is your 4x4 or 4x2?
Old Jul 6, 2007 | 08:43 PM
07screw's Avatar
Mine is a 4x4. what size is the aal?will the aal make the back to high ?What does aal stand for?
Old Jul 7, 2007 | 03:19 AM
ffemt000546's Avatar
aal= add a leaf. if it is only 1/2 a inch off and add a 1.5 then the back will sit 1 in higher
Old Jul 7, 2007 | 06:39 PM
07screw's Avatar
thanks for the input
