Sponsored by: CARiD
Ball joints
Old Jul 1, 2007 | 03:57 PM
brandoon's Avatar
Ball joints
Hi, I have a 1997 F150, I have bolt off the bottom othe ball joint and the c ring off the top can get the ball joint out, tried heat, penetraiting oil and a BFH to beat the heck out of it but it won't budge..... Any hints??
Tahnks Dave
Old Jul 1, 2007 | 04:35 PM
bigdad8214's Avatar
Tahnks Dave
You mean the nut of the ball joint? Put it back on lose. Do you have the jack under the A arm holding the truck up?
Old Jul 1, 2007 | 05:04 PM
brandoon's Avatar
yes the ball joint nut is off, jack stand under frame//
Old Jul 1, 2007 | 05:58 PM
bigdad8214's Avatar
Put the jack under the A arm, That will help compress the suspension and take some of the load off the ball joint.
Old Jul 2, 2007 | 07:56 PM
1/2Breed's Avatar
Ball Joint Jack
I recently replaced upper and lowere ball joints on my 97. I went to autozone and picked up the tool to remove and replace ball joints, the only way to go. Tools were $100 and you get your money back when you return tools.
