Sponsored by: CARiD
What lift to go with?
Old Jun 28, 2007 | 11:34 AM
Nolefan's Avatar
Exclamation What lift to go with?
I am thinking about putting a suspension lift on my 07 screw fx4. I have looked mostly at the 8" Rize and the 6"Fabtech. I want to get a 37" tire on, so I know with the Fabtech I would need to do a body lift also. Which one should I go for? the Fabtech with body lift or the Rize? and does anybody have any idea on how much a rize lift costs? What other modifications would I need to make to the truck if I put a rize lift on? Sorry alot of questions, just learning.
Old Jun 28, 2007 | 11:41 AM
f150monster232's Avatar
I love my rize, but you dont need a B/L lift for 37 on fabtech all you need is a spacer or a/s.
Old Jun 28, 2007 | 12:08 PM
jb27's Avatar
Would that work?? I was thinking that the fabtech would lift the front up by 6" +/- and the back up by 3" +/-. If you added an A/S, that'd lift the front up enough, but the back would be sagging. Would you also have to do an AAL in the rear to 'level' it out??
Old Jun 28, 2007 | 12:27 PM
Bryndon's Avatar
You will void the lift warranty on virtually every lift if you use a spacer with a lift. It changes a lot of geometry. While a lot of guys do it, it doesn't make it right. There's a lot of guys running the Rize, some are sure to chime in.
I'm running a 6" SkyJacker and 37x13.5 DC FCII tires on the DC1 rims (9" wide). I would not recommend a straight 6" with 37s, lots of modifying (including prerunner fender) to avoid contact. Different wheel width and offset might get you there, but I wouldn't mess around.
