Would 39's fit
Sounds like you've already made up your mind but try to find the right backspacing otherwise it's not going to work. If you get too little backspacing its going to rub like crazy on the fenders and bumper. If you get too much backspacing, the tire is going to rub on the suspension components. Good luck. . like I said I've got 10" lift and only think I could clear 38x13.50s without rubbing. .
LMAO! . . what a turd.
Originally Posted by acm8705
He's also running 4.88 gears in front and 4.56 in the rear. So much for having 4 wheel drive.
I have actually been thinking about 39.5x13.5 iroks 40x13.5 ATZ's when my tires where out. I think it is a good setup.
Also if your going to do this your going to want like a 10in wide rim with 5-5.5in of backspacing. Or a 9in wide rim with 4.5-5in.
