Sponsored by: CARiD
Front end Leveling kit or spacers...HELP
Old Jun 19, 2007 | 04:53 PM
Coolkilled's Avatar
I Have a 6" BDS lift with 35" x 13" BFG....and kept the stock front struts with the BDS spacer....can i add a 2 -2.5" spacer or leveling kit with this set up to give me a bit more lift in the front to match the rear height or ..........?
Thanks....I will post some new photos after i get my bushwackers on....you can check out my truck under my name...Later all
Old Jun 19, 2007 | 09:50 PM
wandell's Avatar
I would not stack spacers.
Old Jun 21, 2007 | 12:03 PM
Coolkilled's Avatar
Talking
would replacing the front strut with something stiffer and taller bring thetruck up in the front or do i have to add a spacer or....is a front end leveling kit the answer.....tx
Old Jun 21, 2007 | 12:06 PM
Coolkilled's Avatar
Talking
OR.....how about a better spring, taller/stiffer????
Old Jun 21, 2007 | 08:41 PM
wandell's Avatar
An adjustable (spring preload) coilover shock would be best.
Old Jun 22, 2007 | 01:16 AM
Coolkilled's Avatar
Talking
and this would raise the front end a bit and keep the tire from burying itself into the wheel well and rubbing?
Old Jun 22, 2007 | 09:01 AM
wandell's Avatar
Right. You could crank up the spring preload to raise the front a little.
Old Jun 24, 2007 | 05:06 AM
Coolkilled's Avatar
Talking
sounds good...gonna look into it....
