Sponsored by: CARiD
Adding 4x4 block to4x2?
Old Jun 17, 2007 | 02:22 PM
SAtownTX's Avatar
I want to add a 4x4 block and a 2 inch leveling kit to my 4x2 to clear 35's. right now my fenders sit at front: 35.8 and 37 inches. What all would i need.
Old Jun 17, 2007 | 02:27 PM
top_sgt's Avatar
i used a set of 4x4 blocks with the 4x4 u-bolts. i also replaced the shocks with the 4x4 ones as well!!!!! i bought them from someone on the forum that had lifted their truck. ask here on the forum, and i'm sure someone has a set laying around.
Old Jun 17, 2007 | 02:28 PM
top_sgt's Avatar
as for the front....i used the autospring 2" spacer!!
Old Jun 17, 2007 | 02:30 PM
knighj1's Avatar
I would NOT stack blocks, you can if you want to, but honestly how much more will it cost to buy ONE block the right size?
Old Jun 17, 2007 | 04:56 PM
SAtownTX's Avatar
2wd doesnt have blocks so its not stacking. also top_sgt. any pics of your truck?
Old Jun 17, 2007 | 05:04 PM
Copenhagen848's Avatar
Glad they worked out for you
Lets see some pics.
Old Jun 17, 2007 | 06:35 PM
wxscpo's Avatar
Have you done anything else to your truck's suspension or is it pretty much stock? I don't think you're going to clear 35's on a 2WD by just adding a 2" leveling kit and 4WD blocks (which are only 2" blocks I believe). I could be wrong, but everything I read said a 2WD would need a lift to fit 35's.
Old Jun 17, 2007 | 07:32 PM
I believe you are correct, the 4x4's have larger front springs as well creating more lift.
Old Jun 17, 2007 | 09:40 PM
SAtownTX's Avatar
i got measurments. i am only one inch shorter in front and 2 inches shorter in back than a stock 4x4. if i add blocks, back is same. and a 4x4 needs a front level to get 35's, therefore i will still be one inch shorter if i add a leveling kit so i should fit them
Old Jun 17, 2007 | 11:09 PM
wxscpo's Avatar
I have 35's on my 2WD and by looking at it I don't see how I'd be able to turn the wheel without it rubbing everywhere with only a leveling kit on there. What kind of tire are you looking at going with? Are you replacing your wheels also or sticking with the stockers?
Old Jun 18, 2007 | 03:00 AM
Foxacrombie's Avatar
I agree with wxscpo. I have a 2wd with 2.5 level and a 3" Body lift, and I'm expecting to have to trim my valance when I put my 35s on. I don't think it can be done (safely).
Old Jun 18, 2007 | 04:18 AM
zambonimaxx's Avatar
I just fit 35/12.5 w/ a 3.5 inch spindle lift. You will need at least 3.5 inches of lift in the front...I still get a bit of rubbing, and still have a bit more trimming to do. It will take more than a leveling kit to fit 35's...just save the hassle and save up for a lift so that there are no problems!
~Phil
Old Mar 3, 2008 | 12:21 AM
cmolina07's Avatar
can i get some pics of your set up??
Old Mar 3, 2008 | 01:01 PM
top_sgt's Avatar
i'll try to get some today!!!
Old Mar 3, 2008 | 02:32 PM
Russ47's Avatar
i know a girl "friend" of mine who has a 05 F150 stx 2wd, single cab, short bed and a 2.5" leveling kit with 315/70/17 BFGoodrich a/t's on stock wheels so i know it can be done
