Sponsored by: CARiD
what to do what to do
Old May 29, 2007 | 09:08 PM
jdetten's Avatar
i ordered an as 2.5 level after i did i saw a few people say they have had some problems with it and the you should get the blistien shocks that raise the front 2 inches instead so should i put on the as kit or sell it and save up and buy the shocks
Old May 29, 2007 | 09:10 PM
Heissmann's Avatar
I had a level kit on my 2005 FX4 and never had a problem.
Had level kit installed on my 2007 but later out for 8 inch lift .
I ran 17 x 9 with 35's and 18x 9 with 35's
Only experianced rubbing once while hard turning on a curb.
Old May 29, 2007 | 09:25 PM
jdetten's Avatar
so it would be ok to install the level get a alingment then save up the money for wheels tires and shocks take the level off put those on and get it aligned again
Old May 29, 2007 | 09:32 PM
Heissmann's Avatar
Do it right the first time and save money -- '
Old May 30, 2007 | 10:09 AM
wandell's Avatar
Both methods lift the truck the same way. The only advantage of going with the Bilstiens is you get a much better shock.
Old Jun 2, 2007 | 07:41 AM
sladegriffin81's Avatar
How About Bilstein Shocks And The Leveling Kit To Get 4.5'' Inches? Will That Work? With 3'' Or 2'' Block On The Rear.
Old Jun 2, 2007 | 12:02 PM
wandell's Avatar
No, that won't work. There is a limit to everything. You can't just bolt on a 4 inch longer shock or a 4 inch spacer to lift the front of an IFS truck.
