Sponsored by: CARiD
Limiting straps
Old May 24, 2007 | 01:32 PM
thebigbc's Avatar
Limiting straps
I am not sure if there is already a thread on this or not, but it is a simple question.
What is an accurate way of knowing how long of a strap I need, and where does it typically attach to?
Thanx!
Old May 24, 2007 | 06:38 PM
extremeethan's Avatar
Any strap you add will be alll custom. There is no set lenght you need to plan how you want to mount it then measure or buy like a 18, 20 incher and make it work..
Old May 24, 2007 | 09:10 PM
thebigbc's Avatar
uhhh...
So, let me refine my question a little more. What is it that i measure the distance from, and what do I attach it to (bottom control arm maybe?) I saw a picture of somebody that did it on a newer ranger, and they had one end bolted into the frame, and the other bolted into the lower control arm.
Old May 24, 2007 | 10:18 PM
Honestly no one here is probably going to know this. I have only seen it used once on a new body and it was a custom tab bolted with the big lower bolt for the shock to another tab welded to the either coilbucket or where the control arm mounts. I cant reamaber which one.
Old May 24, 2007 | 10:19 PM
Any way you go it is going to be all custom so youll just have to work it out.
