Have a 4x2...need that 4x4 look.
So I can't seem do figure out the best plan of attack here. I have an '07 Screw 4x2 and would like to get to a leveled 4x4 Screw stance. I am considering the AS 2.5" spacer up front, and possibly 2" blocks in the rear. Since my tire's height only measures around 29" tall (if measured correctly), I would of course need to grab some larger tires to give me that stock 4x4 look. Give me your thoughts.
By adding a leveling kit you are bring the front up level with the rear, adding 4WD 2" blocks to the rear will leave you higher in the back again, just what you got rid of with the leveling kit. On a 2WD if you add a 2.5" leveling kit to the front you can throw some 33's on there and I think that'll give you the stance you're looking for.
Originally Posted by wandell
Or maybe just add a 1 inch lift block out back.
It's going to be tough to get the leveled 4x4 look with a 4x2. With the spacer up front, you are still going to be 2" shorter than a leveled 4x4, however you will be the same height up front as an unleveled 4x4. Throw some 2" blocks in back and you will basically have the same look as a stock 4x4.
