Installing my lift today and ran into some questions.
When taking the tie rod off the spindle, do I just take out the pin loosen the nut and thats it...When I put it back together how high do I tighten it.
Take out the pin and loosen the nut and if you're lucky it might pop out with just a bit of hammering, if not you'll need a ball joint separator (aka a pickle fork). In order to tighten it you'll need to turn it clockwise with a wrench. (sorry couldn't resist that :P ) It should tighten up though without a problem.
