suspension lift for 2wd help!
hi, first time here, i hope somebody can help. i ordered a 2007 f150 supercrew fx2. im looking to lift. is the highest lift you can go a cst 7" suspension? are cst suspension lifts dependable? how high does anybody recommend for a 2wd truck? ive also heard a 2wd truck sits lower than a 4wd? does that mean a lift on a 2wd sits lower than one on a 4x4? any suggestions regarding this will totally help. oh yeah and how big can i go on tires without problems? will the truck be level after the lift? since the factory has a higher back end?
CST makes quality products but they are expensive. A stock 4x4 does sit about 2 inches taller than a stock 4x2. However, a 7 inch lift is a 7 inch lift. Usually, lift kits are designed to level the truck so a 7 inch lift will probably raise the front of the truck 7 inches and the rear about 5 inches.
I have a 6" Fabtech lift on mine. I looked at the larger lifts, but just couldn't justify that much of a cost increase for 1" more of lift. You can go with a 6" lift and a leveling kit that will add another 1.5" to 2.5" of lift then do an AAL to the rear. Also I ended up going with a 5" block in the rear becuase the Fabtech kits come with a 2" block and it leaves the rear end sagging and I didn't want that look.
I also went with the 6' Fabtech. Its a great lift. I added a 2' spacer in the front on top of the lift and a 3' add a leaf in the rear. This gave me a total of 8' lift. Mine now sits the same as a 4wd with a 6' lift.
No, they are not the same. A leveling kit is basically a small suspension lift (spacer) for the front suspension. A body lift is 3 inches spacers that go between the body and frame.
As for ride height between a 4x4 and a 4x2, think of it this way. If you install a 6 inch lift (most common size) on a 4x4 and a 4x2 and park them next to each other, the 4x4 will still be taller because it was taller to begin with.
i was not reccomended to install a body lift because of the new truck warranty. is the leveling kit the same problem? would the dealer have less of a problem with either the body lift of the leveling kit? thanks for all the help so far
how much is a 6" fabtech? how bout the 7" cst? anybody? and how much would it be for a leveling kit and AAL installed? do they come in different heights? and how much are 35" tires for 18" rims anybody?? i heard kumho makes cheaper ones. worth the price?
Price all depends on what you actually go with. For me I went with the basic 6" Fabtech kit and paid $1450. The leveling kit and AAL will be considerably cheaper than that even with the alignment thrown in. As far as 35's again it's all a matter of what yu actually get. Do a internet search because there are tons of sites you will find for prices on all this stuff. Good luck.
anybody purchased or know how much a CST suspension lift for a 2007 2wd? ive found some for about $1900. is that too much? and how much for a leveling kit and AAL to get my truck couple more inches after the lift?
