Higher
Higher
I have a 2004 F-150 with a Fabtech 6" lift w/ 35" tires. Now I want to go higher. Is there anyway i can achieve this without a whole new kit or a body lift. I would like to have 37s. Is it possible?
Thanks for your help
Maybe fender flares or cut outs, or try and see if the 37 will rub and if the do see what you need to do. I know a couple guys on here that arer running 37 on the 6 inch fabtech, so you might be able to do it with minor rubbing
If you add Fabtech's coilovers and crank the preload up you should be able to clear 37's with the right wheel. Some people have added leveling kits to their suspension lifts for a little more height.
