*need opinions*
*need opinions*
Ok, so I have managed to save up $1600 for my lift kit. I am positive I want to run 35" Nitto Mud Grapplers on my stock rim. So, this means i will have to go with no smaller than a 4" kit. But, the thing is, 4" and 6" kits cost about the same. So, would yall go with a 4" or 6" kit?? Also, is it even possible to run stock rims with a fabtech kit? B/c I know you can with a Rancho 4" kit...
I'd go with the 6 inch lift for sure. I'm not positive about running OEM wheels with the Fabtech lift. However, you could fit 35x12.50 Mud Grapplers with the OEM wheels and a leveling kit on a 4x4. There will be some rubbing on the control arms at full steering lock. However, that is because of the width and backspacing of the OEM wheels. A lift kit will not cure that rubbing.
I don't think the stock rims are wide enough for the 35x12.5 nittos, I have the same size tires (ATs instead of MTs though) and when I got them they had the factory stickers on them that said the acceptable rim width range was 9 to 11.5 inches
the stock wheels will fit. take a look at this:
https://www.f150online.com/forums/sh...d.php?t=277895
i'm pretty much positive i'm going with the rancho. but the onlly thing is that the kit doesnt came with shocks. will i be fine with my stock fx4 shocks?
i was plannin on ordering it right here:
http://www.4wheelonline.com/Products...roductID=65094
where did you order yours?
I ordered my kit from 4WP but you could order from here. .
http://rockymountainsusp.com/fd4_F150_04+.htm
