Sponsored by: CARiD
Rize question
Old Apr 19, 2007 | 07:12 PM
nd041189's Avatar
Rize question
I am considering an 8" rize suspension kit and running 37 x 13.5 x 20 tires...not sure what wheels but all i know is 20 x 10...sound good?
to the question-- if i buy a "complete kit" is there anything else i need to do to lift the rear to level, or will the kit be all i need? i always hear of people buying suspension lifts and then putting blocks or add a leafs in the rear to level the truck out...
thanks, any help is much appreciated
nick
Old Apr 19, 2007 | 08:11 PM
wandell's Avatar
The kit should make the truck sit level. As for wheels, I'd go with a 20x9 with between 5 and 6 inches of backspacing, depending on how far you want the wheel/tire to stick out.
Old Apr 19, 2007 | 09:08 PM
ThumperMX113's Avatar
Nope, you'll need an add-a-leaf to make it sit level.
I've got a 2" Deaver add-a-leaf and mine sits perfectly level with the Rize 5" block.
Old Apr 19, 2007 | 09:32 PM
nd041189's Avatar
i want my tires to stick out about 2". i have a 2" autospring leveling kit on right now so does that mean im going to need a higher addaleaf? also, what do you mean when you say 5" block? i that what is used to raise the rear of trucks with suspension lifts?
Old Apr 19, 2007 | 09:37 PM
nd041189's Avatar
i want the mkw m26 wheels. they only come in 20 x 9 with 30 offset and 6.18 in. backspacing.....
i think that is too much backspacing if i want the 13.5 inch tires to stick out..
what do you think would be the ideal backspacing/offset to have the 13.5 in tires stick out about 2"
Old Apr 19, 2007 | 11:07 PM
Check out my gallery, tell me if you like the tire/wheel fitment. My wheels are 20x10 with 4-5/8" backspacing. The thing with the Rize is that it doesn't increase track width at all so what looks right on a truck with another lift won't be the case with yours if you use the Rize lift.
The Rize comes with a 5" block in the rear to create the lift, it replaces the factory 2" block.
Are you going to keep the Autospring 2" on when you use the Rize 8 inch? If so, than yes you'll need a bigger add-a-leaf in the rear to make it level. Otherwise you could pony up and get a custom set of leaf springs from Atlas or Deaver. I think longer shocks would be a need as well but I'm not positive.
Old Apr 20, 2007 | 11:40 AM
f150monster232's Avatar
your going to sit high in the front if u put a 2in AS in the front. i have a add a leaf in the back of mine and i site a 1in high in the front
Old Apr 20, 2007 | 10:50 PM
nd041189's Avatar
alright thanks for the info.
thumper--your setup is ideal. if i end up doin the 8" rize, i will do the 20 x 10 with 4 5/8 backspacing, 37 x 13.5 x 20 tires, take off the 2" AutoSpring, and do a Deaver add-a-leaf. i would also do an edge performance tuner as well as larger gears (because i only have 2.55 right now ).
sound good? you have 37 x 13.5 wide tires right?
anyone know where i can get gears?
Old Apr 21, 2007 | 03:01 PM
Hardhitten's Avatar
Good info, im in same boat looking at what I want to do.
Old Apr 22, 2007 | 02:45 PM
Hardhitten's Avatar
How big is your add a leaf from deaver?
Old Apr 22, 2007 | 05:42 PM
2 inch.
