3 inch body lift
Start soaking all of the body mounting bolts now. You need a large pair of channel locks or a pipe wrench and a friend to hold the round nuts/bushings used to mount the cab. Also, you need a saw to trim a couple of inches off the front of the frame so you bumper/valance will mount correctly. You can use a hacksaw, but a sawsall works better.
Originally Posted by J4CK3D UP
Is there any difference puttin a body lift on after a suspension lift as opposed to putting a body lift on with no suspension lift?
when putting on the body lift what will the exhaust look like becuase the body is now moved up higher .
